Is it safe to defrag my mem card |
lastride Joined: May 03, 2005 Posts: 91 From: Vic, Australia PM |
As the sub says is it safe or not
Cycovision Joined: Nov 30, 2003 Posts: > 500 From: England PM, WWW
There's been a few threads on this lately, and the answer is 'not really'.
The reasons are:
1. It doesn't improve performance at all
2. It uses lots of read / write operations which wear your card out more quickly.
3. Some people have reported that their cards have been left unreadable by the device after defragging, requiring a format.
Hope that clears it up!
Sorry about that i did a quick search and didn't find anything well thanks for the info i shall not defrag my mem card
hyperken Joined: Jun 24, 2002 Posts: > 500 From: Malaysia PM |
It will increase the search speed!!!
If you dont defragement it when you put like 480MB of mp3 in the memory stick you will notice a great delay when the list update!!!
It reduced after u defragement it!!
But one draw back is some program will crash because the files location changed.
T18>T68i>P910i>P1i>Samsung Galaxy Note 32MB>256MB>1GB>1GB M2>2GB M2>16GB M2>32GB SanDisk MicroSDHC |
Sorry hyperken, but I have to disagree with you on that point. Most users have reported that there is little noticible difference in access times after defragging a solid state device, and indeed most of the memory card manufacturers do not recommend defragging for the reasons I listed above.
I'm not denying that you noticed a speed improvement after defragging your card, I'm just saying that for most users it makes very little difference at all and is certainly not worth the risk or the wear and tear on your card
@cycovision, I agree. what you have said has been written in many places I have read and certainly I saw no difference in playing large movies from 2gb memory stick
as for programs crashing because file location has changed??? that would suggest the program had taken the physical address of the file instead of the path and filename. can't say I have heard of that since the days of DOS! and even then it was very rare
max_wedge Joined: Aug 29, 2004 Posts: > 500 From: Australia PM, WWW
hehe, DOS! Give me Windows XP and NTFS anyday!!
I can only concur with cyco and masseur. If you format the card and copy everything back again it will perform the same effect as a defrag (ie: each file will be a saved as contiguous block of data) and will do it with far less disc activity than a defrag.
marlonski Joined: Oct 16, 2004 Posts: > 500 From: UK PM |
@hyperken, cycovision is half man half machine, AKA borg I have to agree with him here.
Personally I would actually format the memory stick via the phones options, I've tried both but find the phone option seems to agree better with my w800's current firmware
SPURIOUS NONESENSE
[ This Message was edited by: marlonski on 2005-12-06 23:46 ] |
AugustusXVII Joined: Apr 26, 2007 Posts: 4 PM |
ok...but would a defrag help if my card refuses to play any mp3 above 4.2 MB in size?? |
strizlow800 Joined: Aug 23, 2006 Posts: > 500 From: Macedonia, Skopje PM |
I think defragmenting the card won't make any difference.
I my W800!
[ This Message was edited by: strizlow800 on 2007-04-26 15:26 ] |
Power_VANO Joined: Jun 02, 2007 Posts: 144 From: Georgia PM, WWW
Defragmentation is VERY I/O Sensitive so it will make your card "die earlier".
If your card is fragmented a lot it is better to just cut all the content and then paste again. |
sapporobaby Joined: Sep 14, 2003 Posts: > 500 From: Finland. Kuwait maybe :) PM |
HEY MAX!!!!!!!!!!! Long time.
I'll take MAC OS and its file system every day. I have not defragged for months and months and have not noticed any performance degredations.
Hey Masseur,
Looks like I am making the move to the E90. I like the fact that Symbian 60 runs on the outside as well as the inside. |
Arne Anka Joined: Nov 05, 2003 Posts: > 500 From: Sweden PM |
The purpose of defragmentation on a HD is to decrease the distance the head has to be moved to read individual files. On a memory card there is no head or other moving parts and hence defragmentation has very little or no affect at all.
kimot01 Joined: Jul 06, 2007 Posts: > 500 From: PM |
i see no difference after defragementing any portable storage device
you can always find one if you know where to look i  myself |
PrettyPistol Joined: Jun 13, 2008 Posts: 3 PM, WWW
i defragged my w600 and had problems, then i stupidly defragged my w580 mem stick and had probs. it makes no discernible difference in speeds, but it f**ks up the file system, at least in both my experiences.... |
