W810 Firmware Details and Bugs |
kabukijep Joined: Nov 27, 2005 Posts: 185 PM |
W810 Firmware Overview
Each firmware revision listed below contains the fixes listed against that revision
R4EA031 : 2006-09-25; Java version upped to 6.5
R4DB005 : Latest available available for SEUS; first documented 20-June: MR1
R4CM001 : first documented 9-June
R4CK003 : flashing bug fixed; camera version remains at 4.5; dropped calls problem for some operators fixed
R4CF002 :
R4CE012 : release version
R4CA026 : pre-release version
Source: changelog and misc details here
Sony Ericsson W810 USB drivers
Sony Ericsson Update Service
Other phones' firmware details and bugs:
W950
W850/W830
K800/K790
K750/W800
Checking your current firmware version: Menu > Settings > General > Update service > Software version
[ This Message was edited by: kabukijep on 2006-10-06 00:05 ] |
Mr Miyagi Joined: Mar 28, 2005 Posts: > 500 From: UK PM |
yup please list all the bugs on here. |
grca73 Joined: Jul 21, 2005 Posts: 200 PM |
R4CE012 latest firmware release version which makes other one prerelease
rds does not work.
[ This Message was edited by: grca73 on 2006-04-08 17:03 ] |
so thats the latest firmwear on da fone? wot is rds
rds is radio feature. info that the radio station sends. |
oh ok, so is that feature meant to be on the handset then?
what network did u get ur fne on? is the rds the only bug u got on urs? no freezin or nething?
[ This Message was edited by: Mr Miyagi on 2006-04-08 17:11 ] |
DUDE! wot is rds? that is the question you should google for.
handset features? get the w810 white paper.
this is firmware and bug reporting. |
at all? could it just be your location? sometimes when fm signal is weak in my place, rds doesnt work either
jeez if that's true that's a major bug. theyve been touting rds as a feature and it doesnt work. funny  |
@ grca73: isnt R4CE012 operator-specific? |
so far that is only one i observed.
heard some other peeps experience camera shutting down just before taking a pic. never happened to me.
videos play much smoother without chopping even 385 kbit/s encoded files with 25 frames per sec.
so the processor must be faster compared to k750/w800, same camera version. |
if it is, it's unlocked and unbranded so which part makes it operator specific.
no known way to unlock it or unbrand with third party softwares yet so i know its not reworked in the shop
regarding rds it works on k750 both phones in hand
[ This Message was edited by: grca73 on 2006-04-08 17:23 ] |
how about the others, how's rds?
i wont be bothered by that; i personally dont like the way rds-enabled stations are displayed on the phone; it's not as aesthetically pleasing as the big bold fonts used when the actual frequency is displayed
[ This Message was edited by: kabukijep on 2006-04-09 16:36 ] |
im runnig R4CE and everynow and again it freezes for no reason,
so so so annoying!
batt life seems very good though?
fatreg
For those of you who are experiencing a freezing issue, what network are you experiencing that on???
also anyone had any camera issues? if so what network???
Fatreg are you going to get the handset replaced or going to wait untill a new firmwear sorts out the freezing bug?
thanks
[ This Message was edited by: Mr Miyagi on 2006-04-09 14:47 ] |
dannytip Joined: Apr 11, 2006 Posts: 6 PM |
Ive just got myself a w810i on o2 UK running firmware R4CE012.
Has anyone noticed once the camera flash has been on about 10 seconds it starts flashing? Is this normal? Seams kinda annoying to me maybe its a bug. The k750/w810 doesnt do it and thats similar brightness.
Also as for standby mode there is no clock like other se models.
As for rds mine works fine  |
