Upd: 2006-11-08] TOSC - The Open Screen Capture (v0.3) |
space2 Joined: Jun 15, 2004 Posts: 218 From: Lund/Sweden PM, WWW
Well, as it's name sais, TOSC is a screen capture program (yep, yet another screen capture program), and it's open (ie. free and opensource).
I wrote it because I know only two screen capture programs: one isn't free and the other is hard to use. So I started to make one which is both free and easy to use. It's not finished, it has some minor/major problems, but since it's already usable, I thought I make it public. More info (and dowload link):
http://space2.wordpress.com/tag/tosc/
And as usuall, any comment/critics/idea is welcome
Changelog:
* v0.3 - finally you can start the countdown by clicking on the green rectangle even if the main app is not in foreground.
[ This Message was edited by: space2 on 2006-11-08 09:06 ] |
Sainty Joined: Nov 30, 2004 Posts: 485 From: UK PM |
space2, you've created some great little apps thanks
Sainty - Ex Vodafone Sales Advisor
Nokia 402 -> Nokia 3310 -> Nokia 3510i -> Nokia 6100 -> SE V800i -> Samsung D500 -> SE K750i -> SE W900i -> SE K800i -> SE P990i -> SE K850i -> SE W960i -> SE C905i -> SE X10i |
nemo66 Joined: Feb 20, 2005 Posts: 29 PM |
Good work, thanks for sharing!!!
nemo66...the best sniper in town! |
Johnex Joined: Nov 26, 2002 Posts: > 500 From: Stockholm/Sweden PM, WWW
Great little app man  |
Jabe Joined: Nov 08, 2003 Posts: > 500 From: Slovenia PM |
Great app, thank you! the 10 second interval is a great addition. |
adnhk1 Joined: May 23, 2002 Posts: 447 PM |
Excellent effort Thanks a million for your contribution to UIQ 3 community I've got a little request, can future versions be added with the capability to capture in jpg format? |
This is my TODO list:
* fix the floating window (ie. it should work even when the main window is hidden)
* add possibility to choose destination directory (ie. where to store files)
* add possibility to choose between different file formats
So, if I'll have enough time, I will add JPG support as well. Right now I choosed PNG, because:
* BMP is too big (one screenshot would take ~230KB)
* PNG is pretty simple (the png encoding part, using zlib, is only 100-150 lines, could be even shorter I think)
But I found some classes in the Symbian SDK which might come handly (a generic image encoder/decoder), so by using these theoretically it would be possible to save in any format these classes support (and I suppose JPG is one of them)
Anyway, I don't have too much spare time, so don't expect it soon, ... but who knows (right now I'm adding some new animations to TABU first)
bluesun Joined: Aug 25, 2006 Posts: 68 PM |
thanks for sharing. |
v0.3 - minor fix, but much more usable  |
ares Joined: Dec 11, 2003 Posts: > 500 From: Coimbra, Portugal PM |
space2, you´re becoming a legend lol
keep them coming
SE w880 + Iphone 4 16gb |
Jornan Joined: Sep 05, 2006 Posts: 59 From: Norway PM, WWW
Thanks. But I have a problem. Where is my pictures? I can't find them after they are captured. Please help me!
Sony Ericsson P990i - the one and the only phone! |
p9nineo Joined: Jun 20, 2006 Posts: 149 PM |
its on your root drive of D:\\ (Memory Stick)
Thanks. Looked under ALL my folders in C: and D:, but not under the root drive
But is it a way to take screen shots faster? I shall take many screen shots, and it take a while between every time you can do it. Is my phone slow or the application?
Sony Ericsson P990i - the on and the only phone!
[ This Message was edited by: Jornan on 2006-11-18 22:57 ]
[ This Message was edited by: Jornan on 2006-11-19 11:42 ] |
