i need 3 uk setting for Sony Ericsson W850i |
joe2097 Joined: Dec 26, 2003 Posts: 16 PM |
Hi all can any one give me the the 3 uk setting for Sony Ericsson W850i?
thanks |
hope this helps
Go to Connectivity
Data Communication
Data Accounts
New Account
PS Data
Give it a name - Three
APN - three.co.uk
Save
Edit
Password Request - Off
Allow Calls - Automatic
IP Address - Blank
DNS Address - Blank
Authentication - Tick Normal, Secure and None
Data Compression - Off
Header Compression - Off
Go to Connectivity
Data Communication
Internet Settings
Internet Profiles
New Profile
Name - Three WAP
Connect Using - Three (named earlier)
Save
Highlight and Select More
Settings
Internet Mode - Http
Use Proxy - No
Save
Advanced
Change Homepage
Name - 3 Services
Address - http://mobile.three.co.uk/hb/K800i/HutchKey (case sensitive)
Save
Go to Connectivity
Data Communication
Internet Settings
Internet Profiles
New Profile
Name - Three MMS
Save
Settings
Internet Mode - WAP
IP Address - 217.171.129.2
Security - Off
Username - (blank)
Password - (blank)
Save
Advanced
Change Homepage
Name - MMS
Address - http://mms.um.three.co.uk:10021/mmsc
Save
Go to Connectivity
Data Communication
Streaming Settings
Use Proxy - No
Save
Go to Connectivity
Data Communication
Internet Settings
Internet Profiles
Select the Three WAP profile
Go to Messaging
Settings
Picture Message
Validity Period - Network maximum
Read Report - On
Delivery Report - On
Content Alert - On
Auto Download - Always
Accept Messages - (Select All)
Message Server - http://mms.um.three.co.uk:10021/mmsc
Internet Profile - Three MMS
s.mark Joined: Aug 22, 2005 Posts: 75 From: London PM |
Will these settings work as settings for java as well? I`ve been trying to get Jimm (ICQ Client) working for ages, and not even Three customer services were any help.... |
imo, you should select that profile for java also, and it should work.
Well, unfortunatelly these dont work. Integrated internet browser and Opera mini are working fine, but Jimm (ICQ) and QuickIM (MSN) won`t connect at all.
A have been trying it for almost 6 months now, never had problem like this on any other network.
The only possible explanation to this would be Three blocking some ports these IM programs needs to access the internet....or something like that....
Does anybody know any solution to this? Or did anybody manage to get Jimm working on Three UK ???? |
obakesan Joined: Oct 03, 2006 Posts: 198 From: London, UK PM |
You should be able to download the settings from 3 over the network. Not sure about the other apps but you can use the normal windows live messenger which is free on 3. If you phone is debranded see my post here about getting it on your phone:
http://www.esato.com/board/viewtopic.php?topic=144951 |
ashyak36 Joined: Jun 01, 2006 Posts: 197 PM |
hm |
i cannot get these settings to work on my w880i, sone of the menus are different,someone please help |
