Forum > Sony Ericsson / Sony > Software, Firmware and Drivers > K750 / W800 Firmware Overview
123 ... 457458459  Next
Author K750 / W800 Firmware Overview
mwarner
Posted: 2005-05-21 18:49
Each firmware revision listed below contains the fixes listed against that revision plus the fixes of all the firmwares below that entry.
Please note that the latest firmware revision will not necessarily be installed by SEUS if you have a branded phone. Please see the bottom of this post for addditional information on UK branded phones.
R1DB001
- Released on SEUS for the K750 on 14/09/06.
- Software versions:
LCD 0
Camera 5.3
R1CA021
- Released by DaVinci Team around 19/05/06.
- Released on SEUS for the K750 on 22/05/06.
- Increased Camera software version. Photo and Video quality, however, do not appear to have changed noticably.
- FIX: The Animated menu items bug for Themes is mostly resolved. After applying a theme with an animated menu, we still need to go to the Settings or Calls menu to start the animation, but it will not disappear again after this.
- JBenchmark 3D LQ: 206
- JBenchmark 3D HQ: 125
- JBenchmark 2: 333
- JBenchmark 1: 3934
LCD 0
Camera 5.3
R1BD001
- Released for Polish operator PLUS for K750 and W800 on 6/4/06
- Available on Wotan server and DaVinci from around 20/5/06
- Beta firmware
LCD 0
Camera 4.5
R1BC002
- Released on SEUS for the K750 on 9/3/06.
- Released on SEUS for the W800 on 18/3/06
- Free memory is now listed in MB instead of KB.
- Photos are now taken as soon as the shutter sound is heard.
- Slight increase in speaker and headphone volume.
- Slight increase in phone responsiveness.
- Prevent IMEI changes through third party tools.
- FIX: Background noise during lower volume calls ('hissing bug') now fixed.
- FIX: All USB transfer issues now fixed.
- FIX: Increased stability in PhotoDJ and VideoDJ applcations.
- BUG: m4a tags are not read with this firmware.
- JBenchmark 3D LQ: 202
- JBenchmark 3D HQ: 126
- JBenchmark 2: 340
- JBenchmark 1: 3889
LCD 0
Camera 4.5
R1BA013
- Released by Cruiser Team on 24/02/06.
- Add new profile in Settings / Connectivity / Device mgmt., possibly to enable phone-based firmware updates.
R1AA008
- Released on SEUS for the W800 around 2/12/05.
- Released on SEUS for the K750 around 9/12/05.
- Fixes MS Duo file transfer issues from the PC to the phone over the supplied USB cable.
- Rotating and zooming into pictures displays an egg timer whilst processing.
- Menu navigation (particularly when displaying thumbnail images) feels faster.
- External speaker sound level increased
- Headphone sound level increased (by approximately 1 bar)
- Reduction of noise when playing low volume MP3s
- Center Weighted Average metering used instead of standard Average metering to improve photos in lower level lighting conditions.
- Further Contrast / Gamma modifications have been made to the display to improve screen image quality.
- BUG: Increased background noise during phone calls when the volume level is set to a low level.
- BUG: Some users are reporting occasional "incorrect parameter" error messages when transferring files from the phone to the PC. For some users, moving the USB cable to another USB port seems to fix the issue.
- BUG: Minor theme issue. With some themes, e.g. Eternal, the highlight can disappear when you scroll up to the Sony Ericsson link in the Themes menu and select Info.
- JBenchmark 3D LQ: 201
- JBenchmark 3D HQ: 122
- JBenchmark 2: 330
- JBenchmark 1: 3814
LCD 0
Camera 4.5
R1NA005
- Released on SEUS for the W800 on 15/10/05.
- Improved battery life over R1N035.
- Fixes for low-tonal audio issues.
- Fixes for Bluetooth audio issues.
- BUG: MS Duo bug still present with this firmware. See the R1N035 entry for possible fixes.
R1N035
- Released on SEUS for the K750 on 12/9/05.
- Released on SEUS for the W800 on 7/10/05.
- Video bitrate improvements over R1L (as good as R1A044)
- Improvements to photo quality (less noise in dark photos, improved viewfinder refresh rate).
- Bluetooth stability improvements.
- Bluetooth security fixes - no longer asks for file confirmations with paired devices.
- Contrast / Gamma modifications have been made to the display for a better overall picture.
- Improved reception (the signal strength indicator tends to be higher than in previous firmwares).
- Increased MP3 volume.
- Backlight doesn't come on again to show time after phone locks.
- Popup menu icon in the WAP browser has been modified.
- Fixed "More" menu when adding addresses to an email message.
- Problem: Battery usage increased by around 20% following the improvements made to reception.
- PROBLEM: Zoom functionality does not work for images greater than 1632 pixels wide and/or 1224 pixels tall.
- BUG: (Fixed in the current revision B?) With some phones Java applications can no longer turn on Bluetooth (i.e. the message "Failed to complete this enquiry" appears rather than the question "Allow application to create server bluetooth connection?")
- BUG: Some phones experience MS Duo corruption after the firmware update. This seems to occur after transferring files over the supplied USB cable. Symptoms include erratic behaviour of the Media Player and problems with the file system such as corrupted or deleted files. Potential fixes are as follows:
- DUO FIX: Do not use the supplied USB cable to transfer files - use a USB memory card reader instead.
- DUO FIX: In Device Manager / Disk Drives select Properties on the Sony Eri Memory Stick and then "Optimize for Performance" on the Policies tab. You will now have to use the "Safely Remove Hardware" in the taskbar before unplugging the phone.
- DUO FIX: Format the memory stick in the phone and then perform a Master Reset / Reset All. Note that this will erase all settings - perform a full backup beforehand. This should be used as a last resort and does not necessarily fix the problem.
- JBenchmark 3D LQ - approx 204
- JBenchmark 3D HQ - approx 123
LCD 0
Camera 4.5
R1N005
- Released by SETool on 30/6/05
- Test firmware for K750.
- Known bugs with this firmware
R1L002
- Released by DaVinci for the K750 on 22/6/05
- Released on SEUS for the K750 30/6/05
- Release firmware for the W800.
- Fixes the O2 GPRS issue introduced in R1J
- Video recording quality as R1J (i.e. inferior to firmwares previous to R1J)
- JBenchmark 1: 3880
- JBenchmark 2: 335
- JBenchmark 3D LQ - approx 201
- JBenchmark 3D HQ - approx 121
LCD 0
Camera 4.4
R1K001
- W800 brown (pre-release) firmware
R1J002
- Released on SEUS 13/6/05
- Standby crash fixed / improved.
- Increased call and Media Player volume.
- Games menu operates much more smoothly.
- Smoother video playback
- General UI performance improvements
- Improvements and bug fixes to Bluetooth headset support.
- The auto focus beep sound has been changed.
- Saving a photo to the Memory Stick is now quicker.
- New MP3 folder on Memory stick
- Fixed the month names in the calendar for various european languages.
- Camera sounds are muted when in silent mode in some firmware locales (EU_1 , but not EU_3).
- Minimised Media Player icon changed.
- SMS 'to' text now black (previously white).
- A "Fully Charged" message is now displayed on screen when the phone has finished charging.
* PROBLEM: GPRS comms has been broken on many O2 phones and some phones from other service providers.
* PROBLEM: Video recording quality (bitrate) has been reduced.
- JBenchmark 1 - approx 3908
- JBenchmark 2 - approx 344
- JBenchmark 3D LQ - approx 205
- JBenchmark 3D HQ - approx 114
LCD 0
Camera 4.4
R1C004
- Vodafone specific (K750 only)
- Released around 3/6/05
- No reported changes from R1A044
- As is the case with the K700, Vodaphone's R1C004 supports DRMed MP3s only.
LCD 0
Camera 3.8
R1A044
- First release (K750 only)
- JBenchmark 1 - approx 3894
- JBenchmark 2 - approx 334
- JBenchmark 3D LQ - approx 131
- JBenchmark 3D HQ - approx 89
LCD 0
Camera 3.8
Access your phone's firmware information
To find out which firmware revision your phone currently has installed, perform the following:
Where < and > represents pushing the joystick left and right respectively.
Sony Ericsson Update Service
Your firmware can be updated through the Sony Ericsson Update Service II (SEUS II). In order to use SEUS you will need to have internet access (preferably Broadband) and attach your phone to your PC via the supplied USB cable.
Note that the required firmware update drivers are present in the following directory after installing SEUS:
C:\Program Files\Sony Ericsson\Update Service\drivers
If you run into problems, you may wish to download and install Sun's Java Runtime Environment separately.
If the firmware update fails part way through, retry the SEUS. If the update consistently fails you will need to perform a Master Reset on your phone. It is likely that you will be required to perform a Reset All - a settings reset is unlikely to do the job. It is recommended to use a tool such as MyPhoneExplorer to create a backup of the data on your phone before performing a Master Reset. Note that you will still lose any games, themes or ringtones present in your phone's memory.
SEUS II will currently install the following firmware revisions for UK phone brands:
Unbranded UK (CDA102338/38) - R1CA021
O2 UK (CDA102338/16) - R1CA021
Orange UK (CDA102338/12) - R1CA021
Vodafone UK (CDA102338/68) - R1CA021
T-Mobile UK (CDA102361/2?) - R1AA008
Unbranded UK (CDA102338/38) - R1BC002
O2 UK (CDA102338/16) - R1AA008
Orange UK (CDA102338/12) - R1AA008
T-Mobile UK (CDA102425/43?) - R1AA008
Unbranded phones from other regions should update to R1BC002 through SEUS II.
Third Party Update Services
Third party firmware updates are available from a number of third party suppliers including DaVinci Team and Wotan Server. The use of third party solutions will theoretically void your warranty (although in practice the phone vendor is unlikely to notice) so should only be used in preference to SEUS for debranding purposes or updating a problematic phone locked out of SEUS by the service provider.
More adventurous members can flash their own firmware using the FAR file manager plugin. An excellent guide to this process has been written for those wishing to try the process themselves.
Firmware Customisation
A plugin for the FAR file manager has been written to give access to the file system of your phone through a standard DCU-60 cable or via a COM port (e.g. Cruiser cable). This plugin allows you to modify the behaviour of your firmware in a number of ways, including the following:
- Remove the SMS storage limit for your phone
- Remove the camera shutter sound
- Remove the DRM limitations found on Vodafone ringtones.
- Add certificates to your phone
- Change / remove default sounds and Java applications on your phone.
- Change the main menu appearance and functionality.
- Finalise a phone after a firmware update by a third party tool.
- Adjust the Photo and Video quality settings of the Camera driver.
See the FAR Plugin thread (and summary thread) for additional information.
Drivers
If you have not yet done so, installing the following drivers will allow your PC to access the media on your phone over the supplied USB cable:
Sony Ericsson D750/K750 USB drivers (K750 only)
Sony Ericsson W800 USB drivers (W800 only)
Follow the driver installation instructions carefully.
Digital Rights Management
Vodafone users should download Sony Ericsson's DRM packager to assign Digital Rights to their MP3s for use on the K750i.
Technical users may also use the FAR Plugin to modify their Customize.xml file and remove DRM checking from their ringtones. Thius can be done by changing the enable-ringtoneplayer-mp3 and enable-ringtoneplayer-aac entries to 'true'.
Other Sony Ericsson Firmware Overviews
K800
K750 / W800
K700 / K500
T610 / T630
[ This Message was edited by: mwarner on 2006-09-16 12:40 ]
masseur
Posted: 2005-05-21 19:12
Jbenchmark1: 3894
Details:
Text: 1011
2D shapes: 971
3D shapes: 658
Fill rate: 371
Animation: 883
Jbenchmark2: 334
Details:
Image manipulation: 228
Text: 636
Sprites: 309
3D transform: 348
User interface: 266
solidsingh
Posted: 2005-05-21 19:31
is that good or bad masseur?
masseur
Posted: 2005-05-21 19:34
just compare it with the K700 in the K700 / K500 Firmware overview
looks good to me
mwarner
Posted: 2005-05-21 19:53
Thanks Masseur. Updated the first post with your JBenchmark 1 & 2 scores.
masseur
Posted: 2005-05-21 19:58
...and I've added a link to this great thread from the "Answers to the most common questions on Esato Forums (FAQ style)"
keep up the good work
Mobile_Phil
Posted: 2005-05-24 18:23
I saw that the original post says R2A044.
Mine is R1A044. Is this old firmware, or what's the deal? I've seen reports from other places with R1A044 as well!
masseur
Posted: 2005-05-24 18:28
I think thats a typo as people have only mentioned R1A044 on Esato
Mine is also R1A044
staiano
Posted: 2005-05-24 20:50
Agreed I have R1A044 as well.
Although my third screen has:
Customization
CDA102337/103 R2A
cxc125953 R1A044
EMEA_6
Content version
PA16
I drink because my country needs the tax
http://www.esato.com/go.php?url=http://se-nse.net/
mwarner
Posted: 2005-05-25 01:21
Oops! Sorry guys! I've ammended the first post.
mb-new
Posted: 2005-05-27 12:23
If you look at k750 taken pictures here http://www.ixbt.com/mobile/review/se-k750i.shtml in their exif info, you'll see
So R1B005 is out somewhere...
BR, Mikhan aka mb
M600 + HBH-DS970
mwarner
Posted: 2005-05-27 12:44
Interesting find mb-new! I wonder if it was some sort of unreleased / test firmware firmware?
[ This Message was edited by: mwarner on 2005-05-27 11:44 ]
francesco_q
Posted: 2005-05-31 09:52
How do i check the firmware??
mwarner
Posted: 2005-05-31 10:17
@francesco_q
Read the first post.
FISKER_Q
X1 Black
Posted: 2005-05-31 19:51
staiano i remember the string is used to apply branding to the phone if needed, and also check for 3rd party firmware flashes.
